9900X - OC scope?
HRL
HRL
22 Nov 2005
Devon
Friend of mine recently bought a new PC.
He thought he’d specced it out spot on and spent an absolute fortune on it, along with a 2080Ti.
However, he thought he’d ordered a 9900K, turns out he actually bought a 9900X.
More cores and slightly lower boost clocks I know, but is there any scope for OC’ing it still? Had a quick Google and there seems to be a distinct lack of OC’ing articles on that CPU, I’m guessing just because it costs a small fortune?
Er the 9900x is for lga2066.
When you say specced it out, do you mean separate parts to build or pre built? If the former he may have a slight issue if he also went with a z390 board.
If the latter then it isn’t an issue beyond costing a whole lot more. Performance is basically slightly above. 7900x with overclocking probably in the same ballpark.
Yep, LGA2066. Prebuilt.
I did laugh when he realised he’d spent £1K on the CPU thinking he was getting a 9900K instead.
OC details online seem a bit limited.
Pretty sure it’s quad-channel RAM so told him to get himself another 2 x 8Gb to go completely OTT.
Can he not send it back? You don't need 4 sticks of ram it will work with 2
He could but he’s perfectly happy with it so why bother.
Thought it would perform better in quad-channel mode anyway.
Remarkable lack of OC information out there but I reckon he should be able to get 4.5 or 4.6Ghz on his AIO.
The difference in duel and quad is very little. But if he's splashing the cash then why not.
Yep, that’s what I told him.
He should be good for a few years I’d say, especially if he gets an overclock out of his CPU.
