I've looked all over the internet in regards to this but unfortunately had no joy.
I've got a PC that comes with SPDIF that is connected to my AV reciever (STR-DE698) and I put in a DVD and open it with VLC media player, although on the Audio section it allows me to choose A/52 over spdif .The multi channel decoding light comes on my amp although the audio is very choppy and completely unlistenable.
Yet when I use the same DVD and load it in media player classic home cinema and select the appropriate SPDIF settings it plays the DVD fine and in dolby digital, the multi channel decoding light appears & dolby digital 3/2/1 scrolls across my amp and all is well. Sounds perfect.
Yet doesnt in VLC no matter what settings I try, I have also looked into the device settings on my audio mixer on my PC and have tried it in 44.1 & 48khz with no difference what so ever. Currently it is set onto 48khz and all dvds work fine in media player classic home cinema.
Same thing applies to some THX audio samples in .vob file formats. In VLC it doesnt decode it in dolby and sounds like stereo. Yet chuck it into M.P.C.H.C and decoding light appears, dolby digital 3/2/1 scrolls across the amp and you hear things flying all over the place.
Any help would be much appriciated
Thanks
Thanks
