in a q6600 system I’m working on, because it is using stock intel cooler, I broke some of the clips trying to fit it after refreshing the paste and while it’s holding on and did have the system running without issue, obviously it’s not suitable, so need a cooler, but not wanting to spend too much.
Anyways I have seen some coolers for 775 for under £5, but state for pentium 4 and extreme editions of that, I am going to assume whether or not being 775 it will fit, that it wouldn’t be sufficient for my cpu right?
Probably won’t try overclocking as the board isn’t the best for that, but I do need a cooler and trying to see my options before settling on an Akasa K25 LP cooler for £10, one which I had before for same cpu, but then I was trying to overclock and then i build it for resale and while I found it good, I do try not to keep buying the same things.
