I will mention though, if you go down this route, i've had trouble with stability when using OCZ RAM with a Gigabyte Motherboard... Might just be AMD gigabyte though.
I'd save a bit on the PSU and get a better case, the Antec 300 is a bit cramped IMO.
You won't need anywhere near 700W to run two 5770's in that rig.
he wouldnt save much if he dropped to a 600-50watt thought only 5-10quid may aswell just stick with it
Even 650W is overkill. A decent 500-550W would do the job easily.
hes says adding another 5770 down the line 500-550 would probably be borderline boot or not
Core i7 Test System SpecsNot a chance, take a look at paradigm's rig (Q6600, 6x 320GB HDD's, 2x DVD-RW's, 2x 5770's AND a 9800GT, as well as a miriad of fans and other accessories), which runs off an Antec HE 550W.
	it would be really close with a pair of 5770's peronally i wouldnt feel comfortable with less than a 600watt psu
