A bay in Corsica
1 Mar 2003
Cotham, Bristol
I quite like the outcome of this :)
cor, me too :D
Very smooth, very ghostly :)
There's some odd mottled effect going on though? Most noticable on the far left rocks, but upon closer inspection, is across the whole image..
Edit : And that lil' red light between the rocks is perhaps a touch distracting, too :)
edit edit : Hang on, or is that the sun! :o
hehe, that is indeed the sun :)
Edit: And I think that lense is little water droplets on the lense or something, which I hadn't noticed till you pointed them out :)
This was the method where I did the following.
1. Set metering mode to spot
2. Set the camera to aperture priority
3. Change the focal point to the sky, take a photo
4. Then change focal point to the water/foreground, take a photo
5. Then let photoshop help you merge the rest.
Someone had suggested I use the centre metering mode. I found that this gave me more or less the same settings for the foreground and background, which of course didn't work very well.
Thats almost as good a sex!
Made me drop my mouth when i saw it! It really draws you into the picture, and its so calming.
If i were you, i would enlage it and paste it as wallpaper on your walls, or even better, on the side of the house!
