A Big Mouse
10 Apr 2004
Cheshire
Looking for a replace for my Logitech G500s as I find it on the little side for my hands. Got looking around and seen either Mionix Naos 7000 or a Razer Deathadder Chroma both big and both get good reviews . Would like opinions of either mouse if you have had or used or recommend another bigish mouse out there suited for mainly palm use
cheers guys
+1 For the DeathAdder Chroma,
I used to have a cordless Logitech Revolution, brilliant fit for large hands, but it never had very good sensitivity for gaming, so I was on the look for a different mouse, this time being corded.
Tried :
Shogun Bros Ballista MK1
Hand kept losing grip of the mouse and the switch where your thumb rests, was annoying
Roccat Kone XTD
Hand kept losing grip on mouse.
DeathAdder Chroma
Both sides of the mouse have rubber pads, so you hand stays on the mouse quite well.
Very light and accurate mouse, plus the braided cord is so light, it feels as if you are using a cordless mouse.
I have (very) large hands and went from Sidewinder (please bring these back!!), to MMO7 (which was adjustable but terrible build quality), G502 now a little small but good enough (crabbing), I've also got a MMO TE which seems better build quality (and large) than the MMO7's but not really used it that much.
Its all personal preference, i have large hands and get on fine with a zowie fk2 been through many a mouse before i settled on one.
Don't like the EC1 personally. Right side lacks support (too slanted), forces hand to be at an angle. Deathadder more symetrical, better balance and easier to lift in my opinion.
Had a Qpad 4k, similar to Naos. It's OK if you want a totally ergonomic mouse. I would prefer the Avior / Deathadder these days. Favourite shape is WMO 1.1.
