Pretty much. The last 32-bit only proc I can recall is the Intel Core Duo (not Core 2 Duo, mind you)burnsy2023 said:Yep, you're fine, all new processors are 64bit IIRC.
BillytheImpaler said:Pretty much. The last 32-bit only proc I can recall is the Intel Core Duo (not Core 2 Duo, mind you)
Arclite said:thanks for the quick replies, one more question which one should i get? there are so many to choose from?
Arclite said:Hmm, at the moment this looks like an attractive option: http://www.overclockers.co.uk/showproduct.php?prodid=SW-041-MS
But not sure though!
Arclite said:Alright then, im gonna look it up but whats the difference between the two?
