- 26 Sep 2008
hi need a couple of bits of advice if anyone can help. My current system-
Asus M3N78
AMD 9950 BE
Xigmatec S1283
2x2 gig Corsair 6400
Asus 4850 512m
Hiper 550W
couple of maxtor 160G HDs
all in a Coolermaster Scout
My other bits-
Razer Diamonback on a Goliathus mat
Merc Stelth keyboard
Creative Fatality headphone
Decent-ish Logitech speakers
Right first question is ive had my 9950 for a while now and its always run hot, around 50 idle 60-65 under load. I bought the xigmatec to try and sort it but have had loads of difficulties installing it. The primary thing being it doesnt seem to fit and leaves about 1mm top and bottom gap. When I finally manage to get the bracket on its probably moved around a bit more. Am I being really stupid and missing something.
Bought the case because of the bit fan on top and a cheap exhaust for my gfx card. The card dropped loads to around 40-45 and the cpu dropped to maybe 45 idle up to 60 under load. (BTW everything is running at stock) Ive seen other people having problems fitting it but the fact if i measure it against the cpu out of the case and it is too small baffles me a bit.
So if anyone can shed any light on that it would be appreciated.
Onto my second plea for advice.
Am probably going to upgrade a bit over the next few months what would you suggest. I tend to upgrade over a few months as I cant throw a lot of money at it in one go. Maybe £150 per month for 3-4 months. Which way would you go?
Would probably prefer to stay the AMD route to keep the ram and possibly mobo initially and want to upgrade the card although I cant see much increase in performance to £150 cards at the moment, would really like a dx11 option that can play BF BC2 maxed.
So to summarise any ideas about the cooling for my cpu (i could then OC a bit and concentrate on upgrading the card for now). If not which CPU should I be looking at before going for a new card and thirdly how important is an expensive mobo (if the cpu is good enough probably wont overclock).
Sorry for the long post.
Cheers
Asus M3N78
AMD 9950 BE
Xigmatec S1283
Asus 4850 512m
Hiper 550W
My other bits-
Cheers
