A boat and a rose
Caporegime
16 May 2003
Was out and about (images link to larger versions):
(200mm, 1/1200 at f/5.6, ISO1600 - no idea why I used 1600, I didn't notice till I'd moved on past it)
(48mm, 1/125 at f/9, ISO400)
Both have been cropped, border added and auto levels in Photoshop.
On a 400D, first photo with my Canon EF 70-300mm f/4-5.6 IS USM, the second with the kit lens.
Any thoughts?
I like the boat picture, and the noise on it too. It was a better mistake than me just when I went out taking photos at low resolution. :( I forgot to change it back after taking some shots for items on that well-known auction site t'other day.
I like the rose picture too, but think you should have used a faster shutter-speed and lower focal range to blur the background.
Thanks for the comments. On the subject of mistakes, I'd been playing with the saturation/contrast settings as well, and the JPEGs look utterly crap - RAW saved me from that one. :)
Good point. I might've played more, but I was running short on time and was wary of some dodgy bugger making off with my gear :p
The DOF button seemed completely useless for shots like that though. :(
Found a tutorial in a magazine for adding DoF with Photoshop, so thought I'd have a play:
If anyone's interested, I could summarise the process.
Thanks.
Fstop11 said:
A great way to add lens blur is by using a Alpha channel and the Filter/blur/lens blur tool.
That's what I did, though the tutorial I've got uses a whole load of dodging and burning in the middle. :)
Pray tell how a faster shutter speed would have helped blur the background at all? :confused:
I'm also confused as to what you even mean by 'lower focal range'...
maybe faster shutter = larger aperture = shallow DoF? :confused:
