** A BUNCH OF TECH LABS CARDS **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
I have just finished rejigging all of our OcUK Tech Labs Cards. All descriptions and specifications updated with new cards, the latest blocks and an update to the thermal paste we are using on our Tech Labs products.
Every OcUK Tech Labs H2O Custom Graphics Card now comes with Thermal Grizzly Kyronaut Thermal Paste applied for the best cooling performance.
All Cards are assembled and pre tested so you will never get a DOA card and can be assured that any bugs are taken care of before your card arrives.
Best of all the service is offered for a very small premium over doing it yourself. In some cases we are beating the individual component prices with a Tech Labs option!
Overclockers UK Tech Labs H2O Custom Graphics Cards feature the finest Graphics Card offerings on the market paired with full cover watercooling block solutions from proven watercooling manufacturers.
Each Tech Labs H2O Custom Graphics Card designed to produce fantastic results for the end user looking for optimum cooling performance as well as increasing headroom for overclocks and reducing noise output from a performance computer system.
Overclockers UK Tech Labs H2O Custom Graphics Cards are professionally installed by watercooling experts who ensure that your hardware is handled with extreme care and pre tested to ensure that it arrives to you in full working order. We install the performance processor of your choice and use premium 'Thermal Grizzly' non-conductive Thermal Materials to enhance the cooling capabilities of the Graphics Card VGA Cooling block and keep your hardware safe.
Included in the installation is precision installed performance thermal pads on all graphics card hot spots including the memory modules and VRM that will increase the thermal conductivity of the Graphics Card Block and allow maximum heat transfer from your performance hardware into your custom watercooling setup.
To install and run an Overclockers UK Tech Labs H2O Custom Graphics Cards in your system, you will need to use appropriate watercooling hardware to support the cooling potential of the block.
Overclockers UK recommends the following for optimised performance:
- A Thick 240mm Radiator for a loop including a single Overclockers UK Tech Labs H2O Custom Graphics Card
A 360mm Radiator for a loop including a single Overclockers UK Tech Labs H2O Custom Graphics Card and a high performance quad core CPU
- A Thick 360mm Radiator for a loop including a single Overclockers UK Tech Labs H2O Custom Graphics Card and an overclocked quad or hex core CPU
- A 480mm Radiator for a loop including two Overclockers UK Tech Labs H2O Custom Graphics Cards and a high performance quad core CPU
These figures should be used as a rough estimate and we suggest that if adding more items into your watercooling loop that you take appropriate measures to enhance your cooling system.
Overclockers UK Tech Labs H2O Custom Graphics Cards provide the perfect platform for GPU overclocking by giving your Graphics Card optimised running conditions to perform at its best and allow you to overclock your system to higher frequencies whilst keeping the Processor and power array on your Graphics Card at a lower operating temperatures.
OcUK Tech Labs H2O Custom GeForce GTX 980 Ti STRIX 6144MB Watercooling Graphics Card @ £619.99 inc VAT
ASUS STRIX-GTX980TI-DC3-6GD5-GAMING with factory standard clocks 1075MHz GPU boost clock and 7010MHz memory speed. The cards with exclusive 12+2 phase AUTO-EXTREME Technology with Super Alloy Power II which is premium aerospace-grade quality and reliability. ASUS graphics cards are produced using AUTO-EXTREME technology, an industry-first 100% automated production process, feature aerospace-grade Super Alloy Power II components for unsurpassed quality and reliability.
Features:
- VR Ready
- DirectX 12 Ready
- 4k Ready
- 6144MB VRAM
Specification
- GeForce 980Ti
- GPU: GeForce 980Ti
- Core Base Clock: 1000MHz
- Core Boost Clock: 1075MHz
- Memory Clock: 7010MHz
- Memory Size: 6144MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2816
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 600W PSU Required
- 250W TDP
- Warranty: 3yr
Only £619.99 inc VAT.
ORDER NOW
OcUK Tech Labs H2O Custom GeForce GTX 980 Ti OC STRIX 6144MB Watercooling Graphics Card @ £699.95 inc VAT
ASUS STRIX-GTX980TI-DC3OC-6GD5-GAMING with factory-overclocked 1291MHz GPU boost clock and 7200MHz memory speed. And also, 1317MHz GPU boost clock in OC mode provides better gaming experience. The cards with exclusive 12+2 phase AUTO-EXTREME Technology with Super Alloy Power II which is premium aerospace-grade quality and reliability. ASUS graphics cards are produced using AUTO-EXTREME technology, an industry-first 100% automated production process, feature aerospace-grade Super Alloy Power II components for unsurpassed quality and reliability.
Features:
- VR Ready
- DirectX 12 Ready
- 4k Ready
- 6144MB VRAM
Specification
- GeForce 980Ti
- Core Base Clock: 1216MHz
- Core Boost Clock: 1317MHz
- Memory Clock: 7200MHz
- CUDA Cores: 2816
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 600W PSU Required
- 250W TDP
- Warranty: 3yr
Only £699.95 inc VAT.
ORDER NOW
OcUK Tech Labs H2O Custom Radeon R9 NANO 4096MB Watercooling Graphics Card @ £459.95 inc VAT
Just 6 inches in length, the R9 Nano graphics card is a revolutionary small form factor, armed with a serious performance punch creating an entirely new high-performance class of Mini-ITX-based PCs. No graphics card has ever packed so much performance into such a small form factor. Now PC DIYers can create innovative and powerful PC designs with radical leaps forward in size, shape, and performance.
Features:
- Vulcan Support
- Mantle API
- DirectX 12
- Open GL 4.4
- Open CL 1.2
- AMD Virtual Super Resolution
- AMD Free-Sync Technology
- AMD XMDA Crossfire Technology
- AMD Liquid VR Support
- Frame Rate target control
- Dual BIOS
- HDMI 1.4a / 4k Video Support
Specification:-
- Stream Processors: 4096
- Core Speed: 1000MHz
- Memory Speed: 500Mhz (1000MHz Effective)
- Memory interface: 4096-Bit
- Memory capacity: 4096MB HBM
- PCI-Express X16 lane required
- 500W or greater PSU required
- Power Connectors: 1x 8-pin required
- Display Outputs: 1x HDMI, 3x DisplayPort
- Dimensions: 154*112*40mm
- Weight: 671g
- Warranty: 2yr
Only £459.95 inc VAT.
ORDER NOW
OcUK Tech Labs H2O Custom Radeon Fury X 4096MB Watercooling Graphics Card From £589.99 inc VAT
The new AMD Fury X graphics card ships with 4GB HBM. HBM is a new high-performance memory standard with vertically stacked DRAM dies and fast microscopic interconnects called through-silicon vias (TSVs). AMD Fury X graphics card features a wide-interface 4096-bit HBM memory architecture enabling higher bandwidth performance and over 3X the performance per watt of GDDR5. To fully harness the power of the GPU technology,
AMD LiquidVR™ Technology enables liquid-smooth visuals and high frame rates, which will provide broad compatibility, plug-and-play ease of use, and stable platform support for tomorrow's VR vendors and technologies. Get quality that rivals 4K, even on a 1080p display while playing your favorite online games thanks to AMD's VSR. Microsoft® DirectX® 12 brings new levels of visual realism to gaming on the PC and gets top-notch performance. Moreover, the card uses PCI Express 3.0 as the standard interface, doubling the data bandwidth of PCI Express 2.0.
Features:
- Watercooled
- Vulcan Support
- Mantle API
- DirectX 12
- Open GL 4.4
- Open CL 1.2
- Dual BIOS
Specification:-
- GPU: Fiji XT
- Core Speed: 1050MHz
- Power Connectors: 2x 8-pin required
- Dimensions: 195(L) x 110(W) x 40(H)mm
- Warranty: 2yr
From £589.99 inc VAT.
ORDER NOW
CHECK OUT THE FULL TECH LABS GRAPHICS CARD RANGE AT OCUK HERE
