A case for 2 x Nvidia 5090 GPU's
7 May 2018
Hi
I'm looking for a case that can fit 2 x air cooled Nvidia 5090 GPU's?
Looking for a case that can give some room for air to these 2 GPU's?
Can anyone adivse on what case would be best?
Thanks
A very large one with a load of high performance fans. Personally I’d go with Enthoo pro 2 server edition XL. It’s a proper pedestal server chassis design with an internal fan wall.
Yes thats the one I'm going for (Enthoo pro 2 server edition XL). The only one I can see that has enough space to get good air flow...its going to get hot under heavy use.
Sorry to necro this if it's too late, but I was in the exact same boat, and bought the Lian-Li Lian Li O11D EVO XL - it's one of the few cases that can truly thermally isolate two GPUS, particularly if they're pass-throughs, like FEs.
OCUK sell them for a bit under £200, which is pretty decent value. The mounting kit to separate the GPU is £6, but you'll need a good Gen5 riser card (suggest a 50cm one with a vertically side mounted PCIe slot facing the rear of the case).
