A case for H100i (mid-tower)
29 Apr 2003
London
I am upgrading my old antec 300 mid-tower, wonderful case but it will not fit a Corsair H100i.
I am looking for case with a Window panel, to fit the following;
ATX motherboard
Single GPU 7950
Corsair H100i
1 sata hdd
1 ssd hdd
1 psu
NO DVD/CD player will be installed.
The case will need to be similar size to Antec 300 - Any recommandations?
I would go for the Bitfenix Ronin, although it is out of stock atm.
YOUR BASKET
1 x BitFenix Ronin Tower Case - Black £69.95
Total : £79.55 (includes shipping : £8.00).
Here is a link showing a H100i and Ronin combo. You would need to make sure your ram is low profile....see 4th pic in link.
http://www.eteknix.com/bitfenix-ronin-mid-tower-chassis-review/4/
Another good link showing you different case compatibility
http://www.overclock.net/t/1144409/...compatibility-thread-page-1-for-full-listings
Thanks,
I have ordered a Corsair Vengence Pro Series 16GB (2400hz) memory sticks for a gigabyte sniper Z87Z motherboard. Will that cause a problem?
I am also thinking about Corsair Carbide 300R or 650D as well.
The ronin and h100 can be set it a lot better than that if your going for push or pull only and then there is no ram clearance issues :)
i have been searching last few days and if you want push/pull then choices are a bit limited
if you google
H80 / H80i / H90 / H100 / H100i / H110 Case Compatibility Thread
you will find a decent thread with loads of info
top of my list was the 750D for the H100i in push/pull but at £150+ its a bit out of my budget
next is the Corsair 540
Roning can do push/pull but its very very tight to top DIMMS for ram.. doesn't actually work on my AMD Chipset. my ram slots are too high up the board
Ronin would be my choice too. :)
Though the C70 is a nice case for the money too. :) (though it does have fan spots on the window Boo!)
The new 230T case by corsair might be worth checking out.
There is room for a 240mm rad but depends on your motherboard.
Fairly new but looks nice and clean with some good styling it is however a slightly budget case but looks pretty solid from what I can see.
Ronin would be top notch, Any questions ur welcome to ask me i have this case :)
hi mate
for push pull on the ronin with the H100i, do you mount the top fans below the top lid of the case or do they fit all inside the case at the top? if that made sense!
would like to order a case today
ronin is no tin stock
so its out of the 650D or Corsair 540
650d is quite an old case, does it still come up as one of the best still?
