A challange - Laptop Tracking\monitoring
14 Feb 2007
I work in a medium sized office with around 200 users.
A number of user have laptops, which I belive are just being used a desktop machine, ie never taken out the office.
Can anybody thing of a way I could track these machines to see when they leave the building. So if a user is not using there machine they way it was intended I can go back to them and say "you've not taken your machine offsite for x weeks" jusitfy to me why you need a laptop and not a desktop.
Kensington lock it to the desk. State its for insurance reasons and they have to get the keys from you to be able to take it home.
Nice Idea but I'd have to do it for every laptop (50+ Machines) in the building.
I wouldn't be able to just lock the 10 or i suspect are just sitting on the desk.
Are they being used on the networked? If they are and its wired you counld monitor the network usage/IP - if wireless you could monitor the wireless location (although not sure on that one)
A scheduled task to do "net time >> c:\temp\netlog.txt && ipconfig >> C:\temp\netlog.txt" would dump the IP address and current time into a text file at C:\temp\netlog.txt. You'd need to find a way to parse the crude log that'd result, but it'd tell you if they're on your subnet or not.
Add a small script to the All Users\Start Menu\Startup folder (so it runs whether they're on the network or not) which records the logon date/time and any active IP address to a text file.
Then, check this file as part of a "desktop health check" you decide to perform in a couple of months time ;)
