A CHALLANGE
21 Jan 2008
England
ok ive already specced it a few times, but i jus want to see what you guys come up with and compare them to get the best.
I need the best possible performance from 200 quid.
-It is likley that it will be overclocked a lot.
-Crossfire support would be helpfull so another ati card can be added at a later date. or SLi but thats a little expensive, or is it?
-Obviously an ATI graphics card, depending on the above..
-do not really mind how it looks, jus needs to perform the best it possibly can.
target - good frame rates on some older games. eg Call Of Duty 1.
any suggestions?:confused:
cheers in advance for any feedback.;)
What parts does that cost cover? A complete rig from top to bottom?
If so you'd be better off buying second hand. I could get a barebones-based rig for that amount, but it wouldn't overclock worth a damn.
EDIT: In my book a complete rig is
CPU
Mobo
RAM
Graphics card
HDD
ODD
Case
Power supply
parts needed are:
-motherboard
-CPU
-hard drive (doesnt need to be anything big)
-graphics card
-power supply
-RAM
so yes, pretty much a complete rig.:cool:
Im planning to buy from overclockers.
this is what i came up with..
Motherboard - http://www.overclockers.co.uk/showproduct.php?prodid=MB-003-OK
CPU - http://www.overclockers.co.uk/showproduct.php?prodid=CP-152-IN
Hard drive - http://www.overclockers.co.uk/showproduct.php?prodid=HD-000-WD
Graphics card - Mabye a 7 series card... not sure
Power supply - http://www.overclockers.co.uk/showproduct.php?prodid=CA-088-AN
RAM - http://www.overclockers.co.uk/showproduct.php?prodid=MY-111-CS
Anything easily improved with simular price?:confused:
totally different spec, better performance?:confused:
cheers in advance..;)
This is a fair bit over the budget but £200 is simply not realistic for a system that will be used for gaming and overclocking. The graphics card is still pretty poor overall but should be enough for what you want.
BFG GeForce 8500 GT 256MB DDR2 TV-Out/DVI (PCI-Express) - Retail £39.99
(£46.99) £39.99
(£46.99)
OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK) £22.99
(£27.01) £22.99
(£27.01)
Gigabyte GA-P31-DS3L Intel P31 (Socket 775) PCI-Express DDR2 Motherboard £39.99
(£46.99) £39.99
(£46.99)
Intel Core 2 Duo E2160 "LGA775 Conroe" 1.80GHz (800FSB) - Retail £37.99
(£44.64) £37.99
(£44.64)
OcUK Huntkey 450W PSU £31.99
(£37.59) £31.99
(£37.59)
Hitachi Deskstar 7K160 80GB SATA-II 8MB Cache - OEM £22.99
(£27.01) £22.99
(£27.01)
Sub Total : £195.94
Shipping cost assumes delivery to UK Mainland with:
City Link Parcel Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £8.95
VAT is being charged at 17.5% VAT : £35.86
Total : £240.75
It's not overclockable, it's way over budget, but it does have a much better graphics card.
Hello there :)
After digging around i worked this out :p
Foxconn P35AX-S Intel P35 (Socket 775) PCI-Express DDR2 Motherboard £39.99
(£46.99) £39.99
(£46.99)
GeIL 2GB (2x1GB) PC2-6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) GeIL 2GB (2x1GB) PC2-6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) £23.99
(£28.19) £23.99
(£28.19)
Intel Core 2 Duo E2160 "LGA775 Conroe" 1.80GHz (800FSB) - Retail Intel Core 2 Duo E2160 "LGA775 Conroe" 1.80GHz (800FSB) - Retail £37.99
(£44.64) £37.99
(£44.64)
Sapphire ATI Radeon HD 3450 Silence 256MB DDR2 TV-Out/DVI/HDMI (PCI-Express) - Retail (11125-00200R) Sapphire ATI Radeon HD 3450 Silence 256MB DDR2 TV-Out/DVI/HDMI (PCI-Express) - Retail (11125-00200R) £27.99
(£32.89) £27.99
(£32.89)
Hiper 425W HPU-4S425 Silent ATX2.01 PSU Hiper 425W HPU-4S425 Silent ATX2.01 PSU £21.99
(£25.84) £21.99
(£25.84)
Sub Total : £151.95
VAT is being charged at 17.5% VAT : £28.16
Total : £189.06
Its most prob gonna clock like a dog and the £10 saving is for shipping it all back when the hiper power supply takes it all out :)
But within budget ;)
