Well I have been looking at some fans but cannot make a decision, at the moment I have 4 xigmatek 120mm the orange ones on my EK 240 rad in push pull, not really impressed with them and the noise is a little much even at 1000 rpm.
Was going to replace them with Cooler master sickle flow but I am not too sure if they are really the right choice.
Am also looking for blue led fans really, but good for radiators and within a budget of £8 a fan so such as Gentle typhoons are out.
Was also looking at getting a couple of fan shrouds and just using push but would it be as good as push pull with the right fans?
So far I have found a few fans which are
Yate Loon 120 x 120 x 25mm Case Fan Transparent with Blue LEDs 1350 RPM : D12SL-12+4LEDB
D12SL-12+4LED Red
Specification
Air Flow 46.0CFM
Noise 23.0 dBA
Speed 1350 RPM
Connector Type 3 pin
Bearing Type Ball Bearing
LED Colour UV Blue
or
Xilence Case Fan 120mm - Blue : COO-XPF120.TBL
Technical Data
Fan speed:
1.400 RPM ±10%
Bearing type:
Hydro bearing
Max. air flow:
68 CFM
Air pressure: 2,3 mmAq
Noise level:
21,2 dB
or
Scythe Blue LED 120mm Case Fan with Fan Controller : SY1225SL12VBL
Manufacturer Scythe
Model Number SY1225SL12VBL
Specification
Dimensions 120 x 120 x 25 mm
Air Flow 33.1 to 66.2 CFM
Noise 14 to 31.8 dBA
Speed 800 to 1600 RPM
Bearing Type Sleeve
Special Features Low Noise Case Fan
PCI Fan Speed Control
Blue LED Lights
or
Coolermaster 120 x 120 x 25mm SickleFlow Blue LED Case Fan : R4-L2R-20AC-GP
Model Number R4-L2R-20AC-GP
Specification
Dimension 120 x 120 x 25mm
Air Flow 69.69CFM
Noise 19dBA
Speed 2000RPM
Bearing Type Long Life Sleeve
Are any of them suitable or should I be looking at something else, need as quiet as possible so they will be on a fan controller as PC is on desk next to me, any help is appreciated
Also liking the Apache Vipers, would 2 of them with shrouds suffice?
D12SL-12+4LED Red
Specification
Air Flow 46.0CFM
Noise 23.0 dBA
Speed 1350 RPM
LED Colour UV Blue
or
Technical Data
Fan speed:
1.400 RPM ±10%
Bearing type:
Hydro bearing
Max. air flow:
68 CFM
Noise level:
21,2 dB
or
Manufacturer Scythe
Specification
Bearing Type Sleeve
Blue LED Lights
or
Specification
Air Flow 69.69CFM
Noise 19dBA
Speed 2000RPM
