A cooler cooler?
25 Sep 2011
I am currently building/finishing off my dream rig. I just need a cooler which will do the job and be more reliable. It MUST have a 280mm rad to maximize on the air intake to my case. I'm going with a white theme as well, so that is quite important. Ideally, I'd like a white cooler with a white light on the pump which measures up to the kraken with a 280mm rad. Now, since I know this isn't possible, I'd like to ask for help and see if anyone has any advice before I go ahead and buy something by corsair or Nzxt.
I've considered building my own loop and that was too expensive although there's some nice looking hardware there, I can customise stuff, and add some individuality to this build (which is what it's all about).
My Rig:
[/IMG]http://imgur.com/ZVtI7oV
Wouldn't recommend the XSPC ion pump. The pump itself is loud and you also have the noise of the pump vibrating through the case.
Could try a DDC or EK SP-60 pump with a white top and heatsink ?
