A Couple of questions for the Zalman Z9 U3
27 Oct 2013
My case comes with 2 3pin fans that go into my fan controller, then ive got 1 rear fan that comes with a molex. Then behind the motherboard is 2 other molex but the problem is my PSU only comes with 2 molex connectors, so i was wondering if you could stack them or something like that and if so could someone explain how and possibly link me a pic?
Also when iv'e looked at unboxings of the case, the usb 3.0 cable is like a normal usb cable that leads through to the back but mine is like 1 cable that looks like one of these - http://usb.brando.com/usb-3-0-dual-20-pin-header-to-usb-3-0-4-port-hub-bracket_p02846c046d015.html
They've either changed the case a little or something is missing....
Also another question: my case doesn't come with bracket's will the hard drive and Ssd come with brackets or what? Ive got these like bolt/screw/mount kind of things but im sure i will need a bracket.. Sorry im a nooob this is my first build.
Heres my build - http://uk.************.com/p/1T8xT
most fan molex's can just be plugged into each other to make a long chain, uply but works.
as fo the other bits a couple of pics could help advise where your going wrong. (or i should have gone to bed a while ago as not able to get my head around it.
photo of inside the case on its side and one of the cable if you dont mind
I believe this is similar to the fan on the Old Z9+ case
