Just had the following kit delivered from OCUK and a competitor which didn't show as prompt of a delivery service!
Core 2 Duo E6600
Schythe Ninja
Asus P5B Deluxe Wifi
2GB Geil 6400 Low Latency
Connect 3D PCI Express x1950xt
Akasa Zen
Creative X-Fi music
I've already got a Tagan 480w Psu that should handle the above rig fairly easily.
I now have the following 2 questions (be nice considering my last build was 3yrs ago and was an athlon xp)
1. The motherboard has a 8 pin power connector which had a rmovable cover over 4 of them. Should I remove the cover and use the 8 pin connector from the PSU or leave them covered and use the 4 pin connector. I think the first way is right but I'm just checking.
2. This is my main problem...
The power supply doesn't have a 6 Pin PCI express power connector so...
Where can I buy a converter if they are available/exist?
Or if they dont exist, can someone recommend me a decent, cost effective PSU for the above rig. I'm not going to upgrade for about another 2 yrs so it doesn't have to be future proof.
Thanks in advance.
(PS. a quick reply would be handy as I'm really excited about getting it up and running)
Core 2 Duo E6600
Schythe Ninja
Akasa Zen
Creative X-Fi music
Thanks in advance.
