I'm building a PC for someone. Long story short they're getting my old components minus case and PSU which is buggered.
Firstly how is the Xigmatek Asgard II as a budget case?
What is the minimum wattage i'd need for a 4870 1gb, q6600 OC'd etc. it's currently on a 600w modxtreme but they're on a tight budget so I'm looking for the cheapest possible PSU that isn't a peice of crap that will blow up and has decent wattage.
On another note, the problem with my old PSU is the fan doesn't work, apart from that it seems ok. Is this a serious problem as I was lead to believe? Am I going to electrocute myself if I attempt to fix it?
