- 10 May 2012
- North London
OK so this morning I noticed when I booted up my System ( I did it 4 times to check it wasn't my imagination, I've never noticed this before)...just after the Beep I always get at boot-up, there is a "Dimming" of everything ..like everything for about half a second loses power ..then kicks back up and is fine , all the LED Fans I have and the Cold Cathode Tubes too , Also the Fans on the CPU Cooler as well , Is my PSU ( Specs as below ) on the way out ?
thanx
EDIT:.....it seems after some more watching boot-ups that its maybe just the two top case fans i have ?, they are set to silent in the BIOS , but even set to standard , the same thing happens ....pc starts to boot up....i hear the beep...then after about 4 seconds the fans dim right down ..almost like they are gonna go off....then they just kick in again and are as they should be , is any of that normal ? I've never noticed that before ...so im a bit lost
thanx
