a E6400 stock with a GTS
Permabanned
26 Nov 2006
guildford, surrey
This is just a quick question for a friend who is buying a pre-built system from a different site. Would an E6400 at stock (he cant overclock it because of the 5300 ram and motherboard) be ok for a 8800GTS at 1280x1024 resoulotion? or what he get some severe bottlenecking at that res in gaming?
thanks.
it will bottleneck it but to a degree that you ll still be able to have all the eyecandy on max etc while staying above 60fps
tomanders91 said:
Is an E6400 comparable to a X2 4600/5000 at stock ghz?
All depends on your application, if your purely talking gaming, in Far Cry, the E6400 will beat an FX62, Halflife it beats an X2-5000, In fear it bearly beats an X2-4600, and in Quake4 its somewhere between an X2-4200, and X2-4600.
Those tests were made by X-Bit labs, at 1024x768 to make sure it wasnt gpu bottlenecking, and to be honest, even the slowest Core2's will be enough power for an 8800GTX 'most' of the time, even at low resolution.
That would be really test sensitive. My tests showd that a C2D e6300@ 2.6Ghz is a fair bit better than my Opteron 170 @ 2.8 when benchmarking.
When I actually play games though, I don't notice it.
