- 23 Nov 2009
- North Leicestershire
Right i somehow need to hook up 4x120mm viper fans to one channel
Problem being vipers are 4 pin Pwm and the only splitter cable i can find is for 3 pin fans
I thought i could maybe somehow solder the wires from all 4 fans together
my idea was to remove the PWM wire from all 4 fans
remove the Green tachometer wire from 3 of the fans
Solder all the 12v and ground wires together to the plug which still has the tach wire on it
reason being is i think if i soldered 4 tach wires together it would possibly confuse the readout on the fan controller so by only having 1 tach wire for four fans i still get an accurate readout for all of them , roughly speaking
