The first of which is that randomly my optical drive will stop workig. It will be still open so I can put a disk in, close will sometimes spin (but not always) and then nothing will happen. To resolve this i need to turn off my PC and re-jig the cables. I'm guessing the answer here is a new optical drive?
Another problem seems to be W7 based, it but I have done multiple fresh installs which haven't change anything. The problem being that I can't switch between windows I have open; alt+tab doesn't work but sometimes just flashes at me, clicking the open icons on the task bar does nothing, trying to do it via task manager does nothing as well and if I minimise something I can't get it back. This doesn't happen all the time but seems to happen at least once a day.
*edit* I have just realised that windows + tab does work so that is less annoying.
I am sure there are a few other little problems but I can't remember them right now, I have just got back from 3 months in Greece so I have forgotten what other annoyances I may have with my PC but will add more if they crop up!
Thanks,
Flare
Thanks,
Flare
