Ive been doing a bit of overclocking on my i7 920, so far im at a lowly 3.0ghz on the following settings.
Cpu ratio, auto
Turbo enabled
Bclk, 143
Dram, 1433mhz 7-7-7-24
uclk, 2866mhz
Qpi link data rate 5161mt/s
Cpu, 1.18v
PLL, 1.800v
Qpi/vtt volts, 1.21250
Dram, 1.64v
Speedstep/c1e disabled
Im looking to push a bit further and im wondering about the qpi link data rate setting, the guide im using suggests setting this to its lowest setting, if i push the bclk up will i have to adjust this. Also when i load up cpuz the memory tab shows my ram running 1T command rate, is it advisable to change this to 2T, ive only ever heard of ram running 1T on nvidia s775 boards. Thanks in advance.
Cpu ratio, auto
Turbo enabled
Bclk, 143
uclk, 2866mhz
Cpu, 1.18v
PLL, 1.800v
Dram, 1.64v
