A few iPhone questions
20 Sep 2003
Scotland
I have a few questions regarding the iPhone, basically its a few things that really annoy me with it.
1. When I am texting it tries to predict what I want to write and most of the time gets it wrong and it’s so annoying. Can this be turned off?
2. Secondly I use iTunes to manually transfer songs to the phone. I also have iTunes installed on my work laptop but when I try and transfer songs it wants to erase all the existing data. Is there a way around this?
3. I setup iTunes with playlists and stick all my albums in individual playlists then drag and drop the playlists to the phone. But when I look at the songs on the phone it doesn’t arrange my playlists like I would imagine, they are all jumbled up?
Cheers!
1) No. Just press the x on the suggested word to carrying on writing.
2) You can only transfer songs TO the iPhone + it's probably moaning about different libraries (see Google for multiple libraries)
3) The playlists still contain the songs, yes? I think it sorts them by alphabetical order.
seems it is possilbe but only if you've got a jailbroken one heres how to do it
http://www.iphonealley.com/forums/showthread.php?t=860
but i'd keep it on, onver time it learns what you type the prioritises words better to your vocab. Might be hit and miss though. But if your not a big texter you probably won't use it enough for it to learn.
I text quite often but it doesn't seem to learn. Despite pressing x all the time it still tries to replace "lol" with "LOL".:(
