Caporegime
- 1 Mar 2008
Before I sell the Saxo, I wanna sort some of it's issues first but need help in how to do so.
1. Handbrake
It's totally fine until you put it on any further than two notches where it's then lodged firmer than the sword of Excalibur.
2. Gear box
It can take some effort to get it into the correct gear with no 'guidance' at all and when in gear, the gear stick can still move relatively freely, meaning that when you want to change gear again, you have to first move it to the position you are already in and THEN change.
3. Clutch pedal squeak
Probably nothing big but may put off some potential buyers. Squeak every time to the clutch pedal is pressed.
Any ideas of cause and solution?
1. Handbrake
2. Gear box
