Hi, I've just got myself a Maxwell Titan X as an RMA replacement for my 295x2 and as I've not had an NVidia gpu for ages now I've got a couple of questions that I'm hoping people on here could help me out with.
First up is what sort of temperatures are expected from these cards? When I put it in with everything at stock I could see (using MSI Afterburner) it was idling at about 60 degrees which seems pretty high and as soon as I did anything 3D it ramped up very quickly to 83 and started to throttle. I did note however that the core and memory clocks seemed to stay at full settings all the time, even when idling and only downclocked when the monitors went into standby, is that normal behaviour?
The fan speed by default seemed to be very low (~35%) so I suspect it just needs a slightly more aggressive custom fan curve?
With regards to overclocking I see in MSI afterburner that I can up voltage, core, mem, power limit as usual but also have a temperature target now as well but even with the fan set to auto it doesn't seem to use fan speed to help meet the temp limit? It just throttles the core speed as soon as it hits the temp limit rather than upping the fan so I presume the fan control is independent of the limits?
Finally, what sort of overclocking can I expect from one of these cards and is it only really possible with significant extra noise from the fan to stop throttling?
Thanks for any help,
Ross
Ross
