Hey guys, just having a few minor problems with my new build hope you guys can help me out. System in my Sig.
First Problem:
I have 2 DVD-RW Drives. A Pioneer and a ASUS lightscribe drive. I connect them both up and then log into windows, the problem is, is that it only sees the Pioneer drive and not the ASUS one. I have tried diffrent IDE cables still no luck, i have tried the ASUS drive on its own and it works fine so its not the drive, any ideas? FIXED
Second problem:
At the front of my Lian-Li PC7 Plus case a light is constantly on, thats the one on the far right, not sure if thats a problem or its post to be like that? FIXED
Third problem:
When i boot up the computer and choose Vista as my primary O/S, it gets to the screen where you choose which account you would like to log into, before it is fully displayed, half the screen is balck then the other half you can see the screen that i was talking about, (Choosing your account), any ideas why it does this? FIXED
Couple of other things i would like to know aswell:
When i go to CPU-Z to check my Memory timmings, it displays the correct timmings and speed, the command rate it 2T how do i change this in the BIOS to 1T, cant seem to find that option anywhere?
Last thing might seem a bit stupid but hey. Im not totally happy with the speed of my Computer as a whole, i was expecting it to be so much faster, it lags every so often when loading things up, simple things as My computer, any ideas?
Ok thanks guys.
First Problem:
Second problem:
Third problem:
Ok thanks guys.
