I've just been playing with Cyberduck, one thing that was missing from the directory list, .htaccess files etc.
When I go to create one in OS X, it whines about them being reserved for system files. True I thought, but why aren't they showing in Cyberduck? Uploading them as text files is fine, but it's no use if I can't actually see the file to download it again when I want to change something, like now.
Next question, text editor with syntax highlighting? The freeer the better.
If there aren't any worthwhile ones in that price range, is Textmate worth it? Dollar rate = wahey at the moment, so it's not so bad I spose.
Next question, I just burned me a CD, will these magical .AIFF's play ok everywhere I insert said CD?
Next, unrelated question, denying access to a file with htaccess, perhaps the php.ini, if I just stick a deny all, allow from my ip, would this stop the site working? I'm not sure I like the idea of people being able to read that file.
Thanking you in advance, I tried to avoid the 'I'm a Mac n00b, help me!' threads the best I could.
Edit: For the text editor I could just be a gimp and install Dreamweaver.
