Hello OcUK!
I'm on the verge of venturing into the world of Overclocking after building my new PC and thanks to the beginners guide sticky it's becoming a bit clearer but I'd just like to make sure what I'm thinking is correct
On it's way is a
- Asus P6X58D-E
- Intel Core i7 930
- Thermaltake Frio
- XFX Radeon 5870
- 850W Corsair HXW
- Corsair 6GB (1600Hz)
- Antec 1200
I'm going to be having both fans attached with the Frio and running at medium and will be aiming for a overclock of about 3.5GHz at first.
Here is what I understand is when I open up the bios I'll be looking for the key things to change, the CPU FSB, the multiplier (This times the FSB = the overall clock speed) and the voltage (The power to the CPU).
I ask if what I believe is correct....finding the CPU speed and clocking it up a couple of hertz at a time, booting up and running a stress test and continuing so until the CPU reaches the speed I want/shows signs of stress. Then I try upping the voltage to see if that prevents the CPU being unstable BUT increasing the voltage = a much hotter CPU.
I also would like to know what's the correct balance? thinking about it is it better to have a high FBS/low multiplier or a low FBS/high multiplier?
And finally I understand that each motherboard uses different references for the CPU speed and etc in the Bios so what should I be looking out for with the Asus P6X58D-E? and if you also have a i7 930 and overclocked what have your experiences been?
Thanks ahead!
On it's way is a
- Asus P6X58D-E
- Intel Core i7 930
- Thermaltake Frio
- XFX Radeon 5870
- 850W Corsair HXW
- Antec 1200
Thanks ahead!
