- 9 May 2005
I have been testing my E2160 (L2 revision/1.325 vid) and Asus P5K-E Wifi over the last few days and managed 3GHz with the stock cooler and stock volts. I have now bought a AC7 Pro and now manage 3.2GHz with 1.4v, I tried for 3.3-3.4GHz but it becomes unstable regardless of extra voltage.
So to cure my boredom I thought I would try some under-volting. The lowest my motherboard goes is 1.1v so I selected that and managed to boot at 400x6 for 2.4GHz. My temps have dropped drastically only reaching 39c (AC7 on ultra quiet mode - 800rpm) full load under prime. I fired up some Source based games which are known to be cpu dependant and I notice no difference at all.
Anyway here comes the questions... seeing as I have been getting load temps of 60+ during the overclocking and over-volting stages do you think I can use the AC7 passive? The fan is only spinning at 800rpm at the moment so surely it can't raise by more than 20c, can it? Also I was wondering if anyone had tried some under-volting in the past and what sort of results they got?
What started off as a bit of boredom has really stoked my curiosity, I am just not sure if when the summer comes it will be logical to be running on minimal fans with passive cooled processor and graphics card.
Oh and by the way... I am even considering updating my bios to the latest 0906 just to get the renowned 0.1 vdrop as I can't select any lower than 1.1v
