A few questions before I make my order ;]
15 Feb 2009
Here's what I'll be ordering,
Now the questions:
1. I've heard that the motherboard might not be sent with the bios that will support Phenom 2 CPU's, and that I'll need to update them. Is this possible without having a supported CPU?
2. After looking through the supported ram for the motherboard, the ram I've chosen isn't listed, however I've seen people saying that it still works, Is this true?
3. I've heard some bad things about XFX, is it worth going for the Sapphire 512MB card? Just to be safe.
Feel free to suggest any adjustments.
Thanks
Thanks
Answer to 2 is yeah it may work and should be fine, and to 3. i had a xfx card once, had it a week and it broke and i wast even into o/c then, however that was long ago and they may have improved since then :D i would cough up the xtra for the saph.
Thanks a lot everyone :]
I'm not sure which PSU I should go with, it's going to be either the Coolermaster 620w or the Corsair 650w.
As for the graphics card, is there much difference between the standard Sapphire 4870 and the "Toxic"?
