A few questions reagarding the 360
23 May 2004
After weighing up the two console I have decided to get the 360 preimum.
My questions are and sorry if I sound a bit dumb...
I have a Viewsonic VX715 and I was wondering whether or not I need an extra cable so that I can use it for the xbox and the pc ?
My other question is whether I can plug the 360 ethernet cable in to my PC which gets the internet via a wireless router?
Many thanks!
You will need to buy a VGA cable for the 360. You will also need a DVI cable or adapter to plug your pc into the monitor.
inferno said:
another question, if i play it in 1280x720 that is 720p right?
thanks
That monitor isn't widescreen though is it, so you would be better off playing at something like 1280x1024 which is native to it anyway?
Yep, so either way i will be able to play it on full screen?
Also, I believe the response is 16ms, is that ok for 360 gaming?
Sorry to dig this up!
