Hi, Ive recieved my parts! YAY! However, I had to RMA the motherboard (P35C-DS3R) as the big radiator thing on top wasnt fitted properly. BOO! Anyway, now that Ive had a look at them in the flesh at least, I have a couple of questions.
Firstly, how hard should you push the lever down to lock the CPU? It seemed to take a fair bit of strain! Yes, I did put the CPU in the right way round-the arrows were aligned and it just dropped in.
Second, how on earth do you fit the mobo in the case!?! I didnt try, but it seemed like it would be a tight fit for the bobo and my hands to all go in at the same time! I have a Thermaltake Soprano.
Cheers!
Cheers!
