- 21 Jan 2007
I've just bought my watercooling setup and, before I put it all together, I want to ask a few questions.
1) I didn't buy a fillport. As far as I can tell its something that connects to the outside of the case. Am I right or wrong? What is a fillport and do I need one?
2) I want to put the whole thing together outside the case then fit it when I'm certain theres no leaks. Is it possible to go from testing to install without having to remove all the water, or is that a bad idea?
3) Bleeding. What is this? I'm pretty sure its removing the water from the system, but how do you go about doing it without getting water everywhere?
4) How do you get the water in there, especially without air holes? If I pour it into the reservoir, does it simply flow around the tubes until its full, or is there something special I have to do to get it all set up properly?
I've bought the following setup:
Laing 10w DDC-1T Pro Pump with Alphacool Top and Water Tank Attachment.
Black Ice GT-Stealth I Radiator.
EK-FC8800 8800GTX Block.
Danger Den TDX 775 Block.
Danger Den Maze4 Chipset Block.
1/2" Tygon Tubing.
Also, anyone tried setting this sort of thing up in an Antec 900 Gaming Case?
1/2" Tygon Tubing.
