A few questions
19 Jul 2004
Hi all,
I have the Q600 running at 3.15 @ stock vaults - temp using coretemp is 52 after playing crysis for 2 hours.
I know this is acceptable but, i have a tuniqu cooler, the fan is pointing vertical and directly above this is a extraction hole so all the hot air is going straight up (thought it may be good as heat rise's) - i still have the usal exhaust fan sucking hot air to the left and 2 incoming fans on the right - you recon its worth puting a fan to help suck the air from above or should i turn the cooler around the conventioanl way?
Also my 8800 GTX is running @ 640/2000 and gets to 75 after playing crysis for 2 hours - would it be worth getting some AS5 on there?
