A Few Vista Tips and Tweaks
18 Oct 2002
Welsh Wales
http://www.neowin.net/forum/index.php?showtopic=499870
If you would like the file, edit, view,tools back in the explorer window just press the alt key , and alt again to hide it.
This thread is for removing the build watermark off your desktop. I can confirm it works for builds RC1 and 5728: http://www.jcxp.net/forums/index.php?showtopic=10458
Here is a list of services I have disabled with no side effects:
Start > Run > services.msc
Distributed Link Tracking Client - Default: Automatic
- Network + Ntfs related, Set to Disabled
IKE and AuthIP IPsec Keying Modules - Default: Automatic
- Set to Disabled
IP Helper - Default: Automatic
- If you don't want ipv4 support, Set to Disabled
Print Spooler - Default: Automatic
- If no printer is present on the computer, Set to Disabled
Portable Device Enumerator Service - Default: Automatic
Windows Media Player Network Sharing Service - Default: Manual
- If no portable device is owned, Set to Disabled
Program Compatibility Assistant Service - Default: Automatic
- If you don't need it, Set to Disabled
Secondary Logon - Default: Automatic
- If you are only running vista with one user, Set to Disabled
Security Center - Default: Automatic (Delayed Start)
- If you don't use the Security Center, Set to Disabled
Server - Default: Automatic
- If you don't plan to send files or print them over a network, Set to Disabled
Table PC Input Service - Default: Automatic
- If you don't have a tablet PC, Set to Disabled
TCP/IP NetBIOS Helper - Default: Automatic
- If you won't be sharing files between computers, Set to Disabled
WebClient - Default: Automatic
- Set to Disabled
Windows Error Reporting Service - Default: Automatic
- If you don't use it, Set to Disabled
Windows Search
-I stopped this and set it to manual (I believe Outlook 2007 uses it)
Superfetch
-Stopped and set to disabled.
Offline Files
After boot up I am showing a 550mb memory usage now :)
Doesn't that negate the point of it being a beta test?
It's an optional choice :) Just as it is to actually send info to Microsoft when it prompts you too. Have it set up as you see fit.
