- 18 Mar 2008
Yes, I should know the answer to the question as I'm doing physics
At the moment, my i7 930 has reached a max of 53'c under load at stock clocks. My gtx 480 has reached about 48'c max at stock clocks. Both are underwater. Room temp is pretty cool, it's the coldest rooom in the house, I think it must be about 20'c.
This is weird as not only is the cpu before the gpu in the loop, but the gpu surely produces more heat?
I'm planning to overclock to at least 4ghz. I imagine that this will mean that my temps could go to 60+
I'm also considering some Mayhems Dye for my system. However, it says that the system has to be between 50'c and -8'c. If both my cpu and gpu are going to be in the mid/high fifties of temp under load, then what is the maximum temperature that the coolant will reach? From what I think I know about physics, I can't imagine that the water will reach anywhere near 50'c? But I'm just making sure.
Thanks
Thanks
