Hi Guys,
Im a 'long time lurker, very few posts' user of these forums, but I recently got my X1900XT from OcUK and hgave a couple of quick questions, having read the board people here seem to be knowledgable and will be able to help me (I hope
1. How can I check the clock speeds on my card are increasing properly in 3d apps (i have dual display set up so can put any second app on my other screen)
- the Cat Control Center ans ATiTool dont show any increase when i run 3d apps (ie CoD2).
2. ATi Tray Tools (my preferred app) doesn't support overclocking in the X19 series
ATiTool wants to do it but only if I leave those clocks set for 2d too (which I dont want to do as I like the quiet running in 2d
) Any app that will overclock in 3d only? Please link me
3. I have a feeling this is my TFT giving me this problem, but seeing as I got the PowerColour3D X1900XT which I guess loads of other people are about to get........In 2d and 3d on certain shades of block colour (only noticable on areas of solid colour) I get a shimmering - almost like a very faint interference pattern or very faint checkerboard effect. If i adjust the gamma/ contrast/brightness on either the card (via CCC) or the monitor I can get the colour to 'lock down' to a solid colour but the problem will shift to another area of the screen (with a slight different shade of colour). As the problem seems to move when I adjust my TFT colour/gamma/brightness I assuming this isnt a problem caused by the X1900 but a prob with me monitor (cos TFT still cant do 32bit colour properly?? or so Ive heard)?
The OcUK forums have been a good example of this as they use several shades of blue, and with slight different TFT settings I getting the prob on different areas of the screen.
Sorry for the long description but I wanted to try and get my point across in detail as this didnt seem to happen on my x800xt (also from OcUK btw)
Anyone else experienced this?
Impy
)1. How can I check the clock speeds on my card are increasing properly in 3d apps (i have dual display set up so can put any second app on my other screen)
) Any app that will overclock in 3d only? Please link me 3. I have a feeling this is my TFT giving me this problem, but seeing as I got the PowerColour3D X1900XT which I guess loads of other people are about to get........In 2d and 3d on certain shades of block colour (only noticable on areas of solid colour) I get a shimmering - almost like a very faint interference pattern or very faint checkerboard effect. If i adjust the gamma/ contrast/brightness on either the card (via CCC) or the monitor I can get the colour to 'lock down' to a solid colour but the problem will shift to another area of the screen (with a slight different shade of colour). As the problem seems to move when I adjust my TFT colour/gamma/brightness I assuming this isnt a problem caused by the X1900 but a prob with me monitor (cos TFT still cant do 32bit colour properly?? or so Ive heard)?
Impy
