a good rig or not?? will be used for 3d rendering and serious gaming
17 Nov 2010
newcastle
Asus TA-861 Black Mid Tower Case
motherboard:
Gigabyte GA-X58A-UD3R Intel X58 Express 1366 Motherboard
cpu: BX80601930 - Intel Core i7 930 D0 SLBKP Bloomfield 45nm,
Core Size: 45nm
- Socket: LGA1366
- Quad Core
- Frequency: 2.80GHz
- Multiplier: 21x
- L2 Cache: 4x 256KB
- L3 Cache: 8MB
- QPI: 4.8 GT/s
- Voltage: 0.8 - 1.375v
- TDP: 130W
cpu cooler:
Corsair H50-1 Hydro Series CPU Cooler
Specification of Graphics cards supplied running in SLI:
1st
Palit 1536MB GeForce GTX 580 GDDR5 NVIDIA Graphics Card
2nd
hard drive:
1TB Hitachi Deskstar 7K2000 Hard Drive - HDD
optical drive:
Samsung Blu-Ray Combo, SH-B123L/RSBP, SATA,
Samsung SH-B123L/RSBP 12x BD-ROM & DVDRW Combo Player
psu:
Powercool PC750UM 750W Modular Power Supply (PSU)
drive & card reader:
2.5" SATA HDD / SSD dock
- 4-slot memory card reader
- black fascia
- Hot Swappable for quick HDD docking
- All capacity HDD supported
Supported Cards
- Memory Stick (MS Pro, MS Pro Duo, Magic Gate, Extreme, Ultra)
- Secure Digital (SD, SDHC, Ultra, Extreme, Elite Pro, High Speed, MMC, MMC Mobile)
- XD (X card, Type H, Type M)
- M2 (Memory Stick Micro M2)
- microSD (microSDHC, High Capacity)
fan speed controller:
KAZE-MASTER-525-BLACK - Scythe Kaze Master 5.25inch Fan Controller, Black
Four channel fan speed controller.
Def a good rig but I would like to see a better PSU , ie Corsair or BeQuiet.
What memory and cost of unit.
I would not power a rig with 2 x GTX 580's using that PSU. I would recommend the new Adata 1200w HM PSU.
I would also like to know what resolution monitor your using? If your only using a single 1920 x 1080 monitor then 2 GTX 580s is overkill and I would suggest buying a single GPU and getting a good SSD HDD instead.
ahem thats the build and im currently bidding on it :D just needed to get some feedback on it, just to know if its really worth it. be the 1st actual PC ive had, if i get it. the memory is 6gb and i havnt got a monitor yet, and im really happy with overkill. lol.
