**A GREAT SSD DEAL FROM ADATA: SP900 PREMIER PRO 256GB!!**
OcUK Staff
17 Oct 2002
OcUK HQ
HI there
Were doing more and more with Adata due to their absolutely superb reliability and the fact they use only the best quality NAND resulting in continued performance and reliability of their drives. As such we've got a great offer on one of their flagship models, check this out:-
Adata Premier Pro SP900 256GB 2.5" SATA 6Gb/s Solid State Hard Drive (ASP900S3-256GM-C) @ £131.99 inc VAT
The Premier Pro SP900 SSD not only boasts impressive performance numbers, but also offers a competitive price advantage to those looking to upgrade. It is expanded capacity solid state drive which uses new optimized firmware to utilize greater storage capacity of the NAND Flash components drive. With superior NAND Flash, the Premier Pro SP900 reaches new levels of stability and performance, with a 7% increase in storage capacity over common SSDs in the market that use a SandForce controller.
The Premier Pro SP900’s maximum sequential read and write speeds are 555/530 MB per second, with maximum random 4k write speeds of 85,000 IOPS. Capacities of 64, 128 and 256 GB make this drive an outstanding option for upgrading notebooks that are compatible with the SATA 6Gb per second specification.
The Premier Pro SP900 SSD adopts specially selected Flash chips from reliable manufacturers, and supports the Windows TRIM command. The Windows TRIM optimization command can directly delete stored data in the Flash memory and release unused space (Free Blocks) to be used for system writes immediately. This results in more accelerated transfer and write performance for solid state drives, and is also effective in slowing down efficiency decline and depletion chances, maintaining effective operation and extending the life of the disk.
In both desktop and notebook computers, users will enjoy an unprecedented high-speed experience when they edit video, retouch large picture, and use computer drafting, reading and writing operations.
Features:-
- NAND Flash: MLC (Mulit-level cell) Asynchronous Flash
- Interface: SATA 6Gb/s
- Form Factor: 2.5 inch
- Dimensions: 100 x 69.85 x 9.5mm (L x W x T)
- Weight: 76g
- Feature: TRIM COMMAND SUPPORT, RAID SUPPORT, MAX 4K WRITE IOPS
- 256GB Performance (ATTO) :
- Read : Up to 555MB/s
- Write : Up to 530MB/s
- Multimedia Data Transfer (AS-SSD)
- Read : Up to 220MB/S
- Write : Up to 255MB/S
- MAX 4K write IOPS up to 90K
- Operating Temp: 0°C ~ 70°C
- Storage Temp: -40°C ~ 85°C
- Shock Resistance: 1500G
- Power Consumption: 0.9W Active; 0.5W Idle
- MTBF: 1,000,000 hrs
- Warranty: 3 year
- Accessories: 2.5" to 3.5" Bracket
- Acronis True image HD,disk Mirgration Utility
Was [£149.99] Inc. VAT
Only £131.99 inc VAT.
ORDER NOW
This price is PRE-ORDER ONLY, stock ETA is end of week so get your wallets out and get buying. :D :D :D
i am not too sure on this, like the brand name and the reputation it holds in the market.
that said, it is a very good offer, but i prefer more of the other ssd offers, please ocuk...
i dunno, the sammy 830 256gb with the cashback offer is 136 quid (after cashback)
not a hard choice really tbh. considering that this uses asynchronous mlc as well, so the performance is roughly on par with the agility 3
