** A Host of NEW EKWB Products **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Perfect timing here, we have a massive amount of new skus from EK Water Blocks. The new products are in a new style and include the new rotary fitting style and new VGA fullcover blocks for various 970 variants and non reference 980.
Keep your eyes peeled for some Tech Labs products featuring these blocks too.
EK Water Blocks EK-FC980 GTX Strix - Acetal+Nickel @ £89.99 inc VAT
EK-FC980 GTX Strix is a high performance full-cover water block for ASUS design GeForce GTX 980 Strix series graphics cards. Please check our Cooling Configurator online compatibility system for detailed compatibility list!
This water block directly cools the GPU, RAM as well as VRM (voltage regulation module) as water flows directly over these critical areas thus allowing the graphics card and it's VRM to remain stable under high overclocks. EK-FC980 GTX Strix water block features a central inlet split-flow cooling engine design for best possible cooling performance, which also works flawlessly with reversed water flow without adversely affecting the cooling performance. Moreover, such design offers great hydraulic perfromance allowing this product to be used in liquid cooling systems using weaker water pumps.
Base is made of nickel-plated electrolytic copper while the top is made of quality acrylic material. The sealing is ensured by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws and washers.
EKWB recommends the purchase of aesthetic retention backplate (EK-FC980 GTX Strix Backplate - Black or Nickel) which improves the looks of your graphics cards and also provide some passive cooling to the circuit board VRM section.
G1/4" threaded fittings can be used on both sides of the FC terminal. Up to four EK-FC980 GTX Strix water blocks can be used on a single ATX form factor motherboard by using EK-FC Terminal (DUAL, TRIPLE or QUAD type) system or other means of interconnectivity. Please note that EK-FC Bridge & Link system is not compatible with this water block.
Enclosed:
- EK-FC980 GTX Strix water block
- mounting mechanism with screw-in brass standoffs
- thermal pads
- thermal grease EK-TIM Ectotherm (1g)
Made in Slovenia - Europe!
PLEASE NOTE:
- Due to immense variety of fittings/barbs available on market and no prescribed standards, we guarantee compatibility only for connectors bought from our web site.
Only £89.99 inc VAT.
ORDER NOW
EK Water Blocks EK-FC970 GTX WF3 - Nickel - Fits Gigabyte Non-Reference GTX 970 @ £89.99 inc VAT
EK-FC970 GTX WF3 is a high performance full-cover water block for GIGABYTE non-reference design NVIDIA GeForce GTX 970 series graphics cards. Please check our Cooling Configurator online compatibility system for detailed compatibility list!
EK-FC970 GTX WF3 water block features a central inlet split-flow cooling engine design for best possible cooling performance, which also works flawlessly with reversed water flow without adversely affecting the cooling performance. Moreover, such design offers great hydraulic perfromance allowing this product to be used in liquid cooling systems using weaker water pumps.
Base is made of nickel-plated electrolytic copper while the top is made of quality acrylic glass. The sealing is ensured by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws and washers.
EKWB recommends the purchase of aesthetic retention backplate (EK-FC970 GTX WF5 Backplate - Black or Nickel) which improves the looks of your graphics cards and also provide some passive cooling to the memory IC on the backside of the circuit board.
G1/4" threaded fittings can be used on both sides of the FC terminal. Up to four EK-FC970 GTX WF3 water blocks can be used on a single ATX form factor motherboard by using EK-FC Terminal (DUAL, TRIPLE or QUAD type) system or other means of interconnectivity. Please note that EK-FC Bridge & Link system is not compatible with this water block.
Enclosed:
- EK-FC970 GTX WF3 water block
- thermal pads
ORDER NOW
EK Water Blocks EK-FC970 GTX TF5 - Acetal + Nickel @ £107.90 inc VAT
EK-FC970 GTX TF5 is a high performance full-cover water block for MSI non-reference design NVIDIA GeForce GTX 970 series graphics cards. Please check our Cooling Configurator online compatibility system for detailed compatibility list!
EK-FC970 GTX TF5 water block features a central inlet split-flow cooling engine design for best possible cooling performance, which also works flawlessly with reversed water flow without adversely affecting the cooling performance. Moreover, such design offers great hydraulic perfromance allowing this product to be used in liquid cooling systems using weaker water pumps.
Base is made of nickel-plated electrolytic copper while the top is made of quality POM Acetal material. The sealing is ensured by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws and washers.
EKWB recommends the purchase of aesthetic retention backplate (EK-FC970 GTX TF5 Backplate - Black or Nickel) which improves the looks of your graphics cards and also provide some passive cooling to the memory IC on the backside of the circuit board.
G1/4" threaded fittings can be used on both sides of the FC terminal. Up to four EK-FC970 GTX TF5 water blocks can be used on a single ATX form factor motherboard by using EK-FC Terminal (DUAL, TRIPLE or QUAD type) system or other means of interconnectivity. Please note that EK-FC Bridge & Link system is not compatible with this water block.
Enclosed:
- EK-FC970 GTX TF5 water block
- thermal pads
Only £107.90 inc VAT.
ORDER NOW
EK Water Blocks EK-AF Angled 90 Degrees G1 / 4 inch - Black nickel @ £12.95 inc VAT
EK-AF (Adapter Fitting) Revolvable angled adaptor (90°) with G1/4" threads.
Adapter allows connection of fitting with G1/4" threads to extend tubing possibilites in your water cooled system.
Technical specifications:
- Material: made of nickel plated brass
- Threads:
* G1/4" BSP; 4,5mm male thread lenght
* G1/4" BSP, 6mm female thread lenght
- Outer diameter of a knurled part: 19,8mm
- Installed height: 28mm
- Sealed with high quality NBR oring.
ROHS compliant!
Please note:
- All AF Angled adapters are hand polished and rounded therefore minor geometrical imperfections are to be expected. This fact does not fall under warranty terms and RMA rights!
Additional Information
Only £12.95 inc VAT.
ORDER NOW
EK Water Blocks EK-AF Angled 2 × 45 Degrees G1 / 4 inch - Black @ £12.90 inc VAT
EK-AF (Adapter Fitting) Revolvable angled adaptor (2×45°) with G1/4" threads.
- Material: made of black coated brass
- Threads:
- Outer diameter of a knurled part: 18,8mm
- Installed height: 36,5mm
ROHS compliant!
Please note:
Only £12.90 inc VAT.
ORDER NOW
EK Water Blocks EK-AF Angled 90 Degrees G1 / 4 inch - Black @ £8.90 inc VAT
- Threads:
ROHS compliant!
Please note:
Only £8.90 inc VAT.
ORDER NOW
EK Water Block EK-TIM Ectotherm (5g) @ £3.95 inc VAT
EK-TIM Ectotherm is a best in-class thermal compound with exceptional value for money. This thermal interface material provides an effective heat transfer and easy application between CPU, GPU or any other PCH/chipset and heat sink.
Ectotherm has been bundled with EK Full Cover water blocks since early 2013 and has been deployed by various system integrators as a cost effective, yet high performance thermal compound.
This Low Viscosity and Electrically Non-Conductive thermal compound makes each application trouble-free and failsafe.
EK-TIM Ectotherm comes in a practical five grams (5g) packaging within a reusable gitf-box and is thus a perfect choice for passionate computer modders, overclockers and computer repair shop personel.
Features:
- High Thermal Conductivy
- Low Thermal Resistance
- Low Viscosity
- Non-Capacitive and Electrically Non-Conductive
- Non-Corrosive and Non-Curring
- No Bleeding & User Friendly
- Density (g/cm3): 3.0
- Net Content (g): 5.0
- Thermal conductivity (W/mK): 8.5
- Optimal working temperature (°C): +100 to -50
Made in China for EK Water Blocks.
Only £3.95 inc VAT.
ORDER NOW
EK Water Blocks EK-FB KIT GA X99 - Nickel @ £90.95 inc VAT
EK-FB KIT GA X99 is a complete water cooling solution for GIGABYTE X99 Series motherboard consisting of two separate water blocks. Please check our Cooling Configurator online compatibility system for detailed compatibility list!
The water blocks directly cools Intel X99 southbridge (PCH) chip and power regulation (VRM / MOSFETs) module. Please note this water block cools exactly as much heat generating components as GIGABYTE factory cooling solution. It is a high flow water block that can be easily used with systems using weaker water pumps.
Base of the waterblock is made of nickel plated electrolytic copper while the top is made of quality acrylic material. The sealing is performed by quality rubber gaskets.
Water block is mounted with enclosed M2.5x4 DIN7985 and M3x4 DIN7991 screws and PVC washers. The 2.5mm nickel plated brass screw-in standoffs are already preinstalled and allow for easy installation.
Enclosed thermal pad is used on voltage regulator module to improve cooling performance of the waterblock. On the southbridge please use any electrically non-conductive thermal grease, e.g. Gelid GC-Extreme.
A maximum diameter of barbs/fittings on SB part of the water block kit must be 22.2 mm in order to allow the installation of the graphics card mounted with EK-FC series backplate in the first PCIe x16 slot! However when using fitting bigger than EK-CSQ Fitting 10/13mm it is mandatory to use EK-CSQ Extender 8mm.
Enclosed:
- 2 x water blocks (MOSFET & SB)
- thermal pads
Fittings are not enclosed! Four fittings are needed to make this waterblock to operate properly. All EK-CSQ fittings are compatible with this water block!
PLEASE NOTE:
- A maximum diameter of barbs/fittings on SB part of the water block kit must be 22.2 mm in order to allow the installation of the graphics card mounted with EK-FC series backplate in the first PCIe x16 slot! However when using fitting bigger than EK-CSQ Fitting 10/13mm it is mandatory to use EK-CSQ Extender 8mm.
Only £90.95 inc VAT.
ORDER NOW
