Titan Bayonet Overclocked Gaming PC - Intel Core i5 7600K @ 4.8GHz Kabylake
Case: NZXT Phantom 410 Enthusiast Midi Tower Case - Gun Metal
CPU: Intel Core i5-7600K 3.8GHz (Kaby Lake) Socket LGA1151 Processor - OEM (Overclocked to 4.8GHz)
Graphics Card: Zotac GeForce GTX 1080 AMP Edition 8192MB GDDR5X PCI-Express Graphics Card
Audio 7.1: High Definition Audio
Motherboard: Asus Prime Z270-K (Socket 1151) ATX Motherboard
Memory: Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-24000C15 3000MHz Dual Channel Kit - Black
Primary Solid State Drive / Hard Drive: Samsung 250GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive
Storage Mechanical Hard Drive: Seagate BarraCuda 1TB 7200RPM SATA 6Gb/s 64MB Cache HDD - OEM
Optical Drive: OcUK 24x DVD±RW SATA ReWriter (Black) - OEM
Power Supply: SuperFlower Leadex 550W 80+ Gold Rated PSU
Cooler: Alpenfohn Brocken 2 120mm Tower CPU Cooler
Operating System: Microsoft Windows 10 64-Bit DVD - OEM
WIFI: TP-Link 450Mbps Wireless N Dual Band PCI Express Adapter
Lighting: BitFenix Alchemy 2.0 Magnetic Connect 15 LED-Strip 30cm - Green
Order Total (Inc. Vat): £1,642.92
Forgive me if this is the wrong place to post this. But I was just looking for a little advice from the community. I wanted a good gaming rig that would last me a while without having to upgrade too much in the near future. I'm a tech novice, from what I have read, this seems to be the best system I could have gotten for the price and job I was looking for (without building the system myself). Anyway, the above pre-built system is the one that I have customised and purchased. But a friend has told me that I might have some trouble with it. Especially with over-heating? As he isn't too sure that I'd get enough power from the PSU and more importantly, adequate cooling? Apparently I should get some kind of liquid cooling? As I will be playing demanding games for long periods of time? Will the above customised system be fine as it is? Or was my more knowledgable friend right? My budget was £1,500, so I am already well over! And from what I can gather, Liquid cooling is quite pricey?
Is it a good system for gaming on as it is? Will it last me quite a good while without having to upgrade? Should I have gone with a better psu and cooling?
Many thanks in advance.
