A little advice please
16 Jan 2012
Hartlepool (North East)
Hi,
I was wondering if some kind person can give me their opinion on the laptop I have selected or narrowed down. I do a lot of gaming, although I have a PC Desktop I am looking to replace my old laptop with a gaming laptop. Reason being is that I find that using a laptop while at home (socially and not locked away in my games room) and portability on LAN Parties and such (as long as they have WiFi)
Games I play are WoW (daily)
League of Legends, Smite, Dota (LAN Party)
As well as newer titles that take my fancy which I have recently bought. Metro, Max Payne, Skyrim (don’t have to be on full settings)
Laptop 1 - Vortex IV X15-970 Gaming Laptop
Processor
• Intel Core i7-4710M 2.50GHz
• 6MB L3 Cache
Memory
• 16GB Hyper-X IMPACT DDR3 1600MHz Memory
• Configuration: 2 x 8GB
Hard Drive
• 1TB SATA II 2.5" 5,400RPM
Optical Drive
• 8x DVD Super Multi (Dual Layer) Drive
Display
• 15.6" Full HD Screen
• LED Backlighting
• Resolution: 1920 x 1080
Graphics
• 6GB NVIDIA GeForce GTX 970M (GDDR5)
• NVIDIA Optimus Technology (Switch between Graphics Cards to increase performance/battery life)
Audio
• Speakers: Premium Onkyo Speakers
Input Devices
• Full UK Multi-Coloured Keyboard with Numeric Keypad
Networking
• Wired: 10/100/1000 Gigabit Ethernet Port
• Wireless: Intel® N135 802.11 Card
• Support: 802.11 a/g/n
• Extras: Bluetooth Support
Dimensions
• Width: 376mm
• Depth: 256mm
• Height: 35mm
• Weight: 3.1 Kg
Laptop 2 - Asus G750JS Gaming Laptop
Processor
• Intel Core i7-4700HQ 2.4GHz
• Turbo boost up to 3.4GHz
• 6MB Cache
• 4 Cores
• Intel® HM87 Express Chipset
Memory
• 8GB DDR3 RAM
• Expandable to 32GB
Hard Drive
• 1.5TB SATA
Display
• 17.3" Auto FHD EWV LED Backlight Non-Glare LCD Panel
Graphics
• NVIDIA® GeForce® GTX870M
• 3GB GDDR5 VRAM
Input Devices
• Keyboard and Touchpad
Networking
• WLAN: Integrated 802.11 a/b/g/n (WiDi)
• LAN: 10/100/1000 Base T
• BT 4.0 support (on WLAN+ BT 4.0 combo card)
Dimensions
• Width 410 mm
• Depth 310 mm
• Height 17 to 50 mm
• Weight 4.8 kg
I know there is an obvious difference in the two but I don't want to be paying too much for what I use it for. I also want it to last the longer the better.
The 1st laptop l am assuming is based on a Clevo chassis, it has a slightly faster CPU and a "newer" faster GPU, the design of these laptops are generally understated compared to other brands, the dual cooling solution "should" be quite quiet and effective.
The Asus will be of a premium finish with its styling, l owned an Asus G46VW and its finish was immense, fantastic build quality and finishing touches.
My P170EM however looks more like a business laptop with a mult-colour backlit keyboard.
Speed wise and portability the Vortex has it for me, for beating of zombies when the battery dies the Asus gets the nod.
