Permabanned
(on behalf of a friend)
Hi all,
I'm new to this whole overclocking business. I have an AMB Sempron 3100+ cpu on a Foxconn 760GXK8MC mobo.
I have clocked the cpu from the standard 1.8 ghz to 2.16ghz. The voltage supplied to the cpu is my problem at the moment.
In bios the voltage began at 1.4v, i then upped it to 1.425 without a problem. After a bit more clocking i upped it to 1.45 and the reading on CPU-Z wouldnt go above 1.44v. Again I tried to increase the voltage in bios, this time upto 1.475, and then later on 1.5v. The actual voltage however refused to go above 1.44v according to CPU-Z.
Why might this be?
As I said I'm new to all of this, so its kind of trial and error at the moment! Any pointers would be appreciated.
Oh yeah, another thing. The highest temp I have reached under stress is 54*c, and according to Core Temp the max temp for my cpu is 69*c. How close to this figure would you say is safe (under stress or idle?).
I hope my questions make sense, any questions please ask.
Thanks a lot,
Chris
Hi all,
Why might this be?
Thanks a lot,
Chris
