a little bit of advice if possible?
5 Feb 2009
N. Ireland
howdy folks,
just looknig a quick bit of advice.
currently my bt home hub (will replace with something fancier in the near future) is situated in my man cave upstairs.
i plan on running a 30mtr ethernet cable up into the roofspace and down the walls into the living room where i want to hook the tv, blu-ray player, sky box and htpc up to the net too.
is just as simple as getting a 5 port switch and some shorter cables to run from the switch to the individual appliances?
also would the htpc be better off on its own internet cable instead of through a switch?
and finally!
anyone spec me a nice plain -(preferably black in case i'm unable to hide it away)- switch for the job or the relevant necessary equipment?
cheers
howdy folks,
Yes
It'll make very little difference. But, unless there's a good reason not to, I'd install two cables just in case.
and finally!
The TP-Link 5 Port Gigabit Desktop Switch here is cheap and cheerful and would do the job.
cheers
