A little guidance on my first build?
5 Aug 2013
CPU: Intel Xeon E3-1230 V2 3.3GHz Quad-Core Processor (£176.39
Motherboard: Gigabyte GA-Z77X-UD3H ATX LGA1155 Motherboard (£121.00
Memory: Patriot Signature 8GB (1 x 8GB) DDR3-1333 Memory (£37.15
Storage: Sandisk 128GB 2.5" Solid State Disk (£64.96
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive (£45.59
Video Card: MSI GeForce GTX 760 2GB Video Card (£219.14
Case: NZXT Phantom (White) ATX Full Tower Case (£100.46
Power Supply: XFX 650W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply (£74.09
Optical Drive: Asus BW-12B1ST/BLK/G/AS Blu-Ray/DVD/CD Writer (£77.12
Operating System: Microsoft Windows 8 (OEM) (64-bit) (£69.59
Total: £1022.64
(Prices include shipping, taxes, and discounts when available.)
(Generated by ************ 2013-08-06 09:10 BST+0100)
It has become quite a bit over my original budget of £800. Thoughts on this list and any ideas on making it cheaper please??
I will be using 3D software/image editing: zbrush, 3ds max or maya or blender, adobe CS6 various image and web editing software (and the usual usage of internet, watching movies, and maybe light gaming)
You still need to remove the link, swap the Xeon out for an i5.
I'm going out in a bit, however when I'm back I'll spec it up.
What's your budget?
why are you putting a Xeon in?
I was originally going to put in an i7 3770k but firstly i'm not really intending to overclock it and secondly I've been advised that the only differences between that and Xeon is that i7 has a built in GPU which I have already got on my list and that the performance is better but not as good value for money.
What's your budget?
I was told that for 3D software you need lots of threads and hyperthreading which i7 and Xeon are good at as far as I'm aware. Is a higher spec i5 as good with that?
Budget was £800 but I am willing to pay extra if I feel I really need to, it's just my first list seemed a bit steep
Just get a 3770 non K edition. Xeons are for workstations and servers where there is little margin of error. Standard gaming/overclocking motherboards generally don't support these processors.
The E3 1230 V2 is a solid chip and well worth the money. You're right enough choosing this, for what you're going to be doing the extra threads should help a fair bit. The E3 1230 V2 is effectively i7 for i5 price. The i5 only has 4 threads while this has 8. It should be compatible with most if not all 1155 motherboards providing the BIOS is recent enough.
OP: I'd buy a cheaper motherboard. The one you've chosen is way more than you need.
http://www.overclockers.co.uk/showproduct.php?prodid=MB-364-GI&groupid=701&
No point in spending more than you have to.
