Hey guys,
I've just been building myself a new system but i'm having problems... hoping you experienced guys can help me out.
So the basics are:
Asus Sabertooth Z170 mk1
Skylake i7 6700k
Corsair vengeance 3200 ddr4
2 x EVGA hydrocopper 980ti
intel 730 series SSD
So my problem....
Well first things first - anyone have this board? The manual states the power indicator led is green but mine is most definitely amber.
I went to boot up for the first time and the rig powers up, the d5 pump spins up, fans come on and the gfx cards light up.
Things go a little weird here - initially both cards light up, but the SLI bridge stays dark. Then after a few seconds the top 980ti goes dark and the SLI bridge lights up, then a short while after that the SLI bridge goes dark and the top 980ti lights back up and there the system stays forever more with both GFX cards lit up and the SLI bridge dark.
I don't get any video, but there is a signal (the screen says 640x480 as it resizes and no longer displays the no input sign). I don't get any beeps but I think at this point it is stuck before posting.
I carefully bumped the GFX cards out of the slots and disconnected the power to them, and then the PC boots up and works fine. I managed to install windows, and everything seems hunky-dory.... The odd thing is that the Q-LEDS are all lit up amber, which is supposed to mean that they failed in post according to the manual.
I then tried re-inserting the 980 Ti's and clearing the RTC by shorting CLRTC for 10 seconds. Unfortunately back to the same old problem of nothing happening beyond my strange little issue with the GFX and SLI bridge playing lights on/off.
Any suggestions as to where I have gone wrong here?
Build log is here if you want to see the system in more detail:
https://forums.overclockers.co.uk/showthread.php?t=18714459
So the basics are:
Skylake i7 6700k
So my problem....
