Hi
Looking for a little help and advice as to what to try next. I recently purchased a Gainward GTX580 "GOOD Edition" 1536MB GDDR5 PCI-Express Graphics Card and ran into some stability troubles under windows 7 64, both within the normal OS and using the card under moderate 3D load (StarcraftII and some rift for testing).
Problem ranges from 30 min usage then freezing / hanging up. A Lot of driver resets, screen going blank, and then coming back on, windows saying the driver has failed then manage to restart.
When you try to load the GFX with 3D games (StartcraftIIa / Rift) you get around 15 - 20 mins of stable game play then the same things happens, black screen / freezing / locking up and needing to reboot.
Even with the software provided with the card, when you clock it right down to virtually no load, the same behaviour happens under windows, freezes / locking up.
I have tried the latest Nvidia drivers (280) and also the last stable version before that also (275.33) and even tried Beta drivers, all using the clean install method.
Same things happen, freezing / locking up under virtually no load. Also swapped the GFX slot on the motherboard to no avail same behaviour, and re-seated all the power connections + system memory as a last resort.
I though the card maybe faulty so got it RMA’ed back to OC and it was tested OK on their rigs, so I’m back to square one really.
I guess the last resort is a full system wipe / re-install OS with latest drivers etc and see from there, is there anything else you guys reckon I should be trying to narrow this down??
Any help / hints would be appreciated.
My other hardware is:-
(Currently running a GTX260)
Case Zalman Z Machine Black.
Motherboard: Gigabyte GA-MA790X-UD3P
Motherboard Chipset: AMD790X
Motherboard BIOS: 6.00PG
CPU: AMD Phenom(tm) II X6 1090T Processor (6 CPUs), 3.2GHz
Memory: Kingston HyperX 4GB (2x2GB) DDR2 PC2-8500C5 1066MHz Dual Channel (KHX8500D2K2/4G) - 8GB Total Memory Latency:
PSU: Be Quiet Dark Power Pro 750Watt
Thanks.
Thanks.
