A little help (maths - again)
17 Sep 2008
Just what i want to be doing on a bank holiday!
So i have said formula:
E=0.0615log10[4]/[K]
I am having trouble making K the subject as i don't no much about logs in this context. Can anyone give me any hints?
Much appreciated,
Luke.
If its E = (0.0615log10[4]) / [K]
then surely it's just K = (0.0615log10[4]) / [E]
however if it is. E = 0.0615log10(4/k)
then....
E = 0.0615log10(4) - 0.0615log10(k)
0.0615log10(k) = 0.0615log10(4) - E
log10(k) = log10(4) - (E/0.0615)
k = 10^(log10(4) - (E/0.0615)
k = 10^(log10(4)) / 10^(E/0.0615)
k = 4 / (E/0.0615)
k = (4*0.0615) / E
k = 0.246 / E
Is this correct?
E = 0.0615log10(4/k).
let a = 0.0615.
E/a = log_10(4/k)
10^(E/a) = 4/k
k = 4 / 10^(E/a) = 4.10^(-E/a)
(. = multiply)
so Mason, no I think you went wrong when you got rid of '10^' in 10^(E/0.0615)
he wont need to know anything about logs in one context so it should be obvious...
op: do you know what the inverse operation of log_10(x) is?
No, i think that maybe the problem.. Could you briefly explain?
First of all i did what mason did in his first re-arragment but i dont think its that simple! E is 0.1 btw i forgot to include it..
10^(log(x)) = x
log(10^x) = x
inverse of a function, f, call it f` => f( f'(x) ) == x.
therefore if you want to 'pull x out' of y = log( 13/x ), you would want to apply the inverse of log.:
10^y = 10^(log(13/x))
and then use the fact that 10^log(x) = x to get,
10^y = 13/x
let a = 0.0615.
E/a = log_10(4/k)
10^(E/a) = 4/k
(. = multiply)
You are correct, I ignore the 10^ on the denominator d'oh!
